| Version(s): | CONNECT EDITION (10.09.00.74) |
| Environment: | Windows 10 (64 bit) |
| Area: | Configuration |
| Subarea: | |
| Original Author: | Soham Mhaskar, Bentley Product Advantage Group |
For certain Components if the Shop Field value is Blank then it can be made Shop. This wiki will illustrate in how to achieve that.
1. Since the Field in OPM is blank it resulted in an empty field in the Report column.
2. Open & edit the specs in the following field as 2 for Shop.
3. Using Pipeline Manager edit the Pipeline using Spec Validation post making changes in Spec column.
4. You will get the desired result in OPM.
communities.bentley.com/.../how-to-configure-dummy-leg-support-in-opim
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
