| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | General Information |
This article details how Workspaces and Worksets can be used to create and share projects within your own custom Design folder location on a shared server.
Note: An overview of Workspaces and Worksets can be found in this article.
1. Create Shared Workspace
Create a new Workspace by selecting the dropdown > Create Workspace.
Enter the Workspace name, for example Shared Energy Simulator Projects:
Select Browse on Root Folder location, and set to the shared server location:
2. Create a new Workset
To create a new project, select your Shared Energy Simulator Projects Workspace, and from the Workset pull-down select Create New WorkSet. Give the Workset a name and change the Root Directory to the location of your design folder:
3. Create the DGN model
Create your building model in the new Workset by clicking on New File. The DGN must be located within the Workset selected. Do not Browse to an alternate location. Simply enter a name and click OK.
The software will now open your new project.
Then, for other users on other machines who also wish to access the same project, start OpenBuildings Energy Simulator and do as follows:
For further guidance on configuring Workspaces on your server, along with how to import a template Workset, please see video here.
