| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | General Information |
Project data such as custom materials and constructions will often be needed in multiple projects.
Rather than having to create such data for each project, OpenBuildings Energy Simulator allows you to use existing data by selecting a template.
Please note that selecting the Template as "None" is perfectly fine, the Workset will be created as shown here.
To do so:
Upon pressing OK, the new Workset will be created inclusive of the "Example Workset" project data.
