| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): |
10.06.00.23
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | OpenPlant Project Administrator CONNECT Edition |
| Subarea: | Associated Items |
| Original Author: | Deepak Singh,Bentley Product Advantage Group |
In OpenPlant Modeler CONNECT Edition, requirement is to create a new associated item using OpenPlant Project Administrator CONNECT Edition
In OpenPlant Modeler CONNECT Edition, creating a new pipeline shows default associated items as Unit Service & Plant Area, refer image as shown below.
Below wiki article explain the customizations to add a new associated item as FACILITY CODE.
- Launch OpenPlant Project Administrator CONNECT Edition.
- From Settings ribbon, expand your desired workset & select OpenPlant Modeler. Click on Schema Editor as shown below.
- From Schema Configuration dialog, enter class name as Plant Breakdown Element & click on Search icon as shown below.
- Expand Plant Breakdown Element class, right mouse on it & select Add Derived class to add a new class as FACILITY CODE. Refer image below.
- Enter class name details as FACILITY_CODE & Display Label as FACILITY CODE as shown below.
- Click on OK to proceed.
- Notice that FACILITY CODE class name enlisting under Plant Breakdown parent class as shown below.
- From Properties, select NAME property & click on Mark Property as Business Key tool. Refer below image.
- Click on Save to save the setting.
- Once done click on Close to close the Schema Configuration Dialog.
- From OpenPlant Project Administrator CONNECT Edition, switch to Settings ribbon & select Property Display Tool, refer image as shown below.
- From Schema Configuration dialog, search for FACILITY CODE class. Expand Name property & make General Status & Status in Element Information as Editable as shown below.
Note: Once Name status has been changed, ensure to click on Tab key from your keyboard.
- Click on Save. Refer above image for sequential steps.
- From OpenPlant Project Administrator CONNECT Edition, switch to Settings ribbon & select Associations option as shown below.
- From Schema Configuration dialog, click on Add (+) icon to include a class as associated item.
- From Select Class dialog, search for FACILITY CODE & click on Select Class as shown below.
- Likewise, click on Add icon again & add Pipeline class as shown below.
- Once done, added association classes will enlist as shown below.
- From Schema Configuration dialog, click on Pipeline class, drag it & release it on FACILITY CODE class, refer image as shown below.
- Notice that it asks to create/define a relationship as shown below.
- Enter relationship name as FACILITY_CODE_HAS_PIPELINE.
- Under Define Relationship dialog, click on three dots against Source Name & search for FACILITY_CODE as shown below.
- Under Define Relationship dialog, click on three dots against Target Name & search for Pipeline class as shown below.
- Once Source Name & Target Name have been defined, click on OK to proceed further.
- Click on Save to save all the settings.
- Launch OpenPlant Modeler CONNECT & verify the newly created associated item.
communities.bentley.com/.../how-to-show-section-material-details-for-structural-component-in-openplant-modeler-connect-edition
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
