Product(s):
OpenBuildings Designer
Version(s):
CONNECT Edition
Area:
Drawing Views
Problem Description:
How to create and apply a Display Style Rule to elements in OpenBuildings Designer.
Steps to Accomplish:
- Click on the Display Style List icon:
- Click on the ellipses to open the Display Styles dialog:
- In the Display Styles dialog, create a new Display Style and rename accordingly:
- In the Render Mode section, set the Display to Filled Visible Edges, and click on Edit Display Rules:
- In the Display Rules dialog create a New Display Rule Set:
- Click on the New Display Rule Set and create a New Display Rule:
- Click on the New Display Rule and from the Pick property dialog choose ELEMENT > Wall > Is Wall:
- Now, for your new Display Rule add a Display Rule Action by clicking on the green "+" icon:
- Follow the same steps for Rectangular and Round Duct:
- Set the display style's active Display Rules to Custom, and double click on the display style name Custom Rule 01 to apply it:
The overrides defined in your display rule will now be applied.
