| Area: | Platform Tools | ||
| Subarea: | Visualization |
Problem Description
When I use the Vue Rendering tool it is not working correctly and is displaying empty as shown in the image below.
If the Vue Rendering dialog is empty first update your graphics card drivers to the latest version and then restart your PC.
If an older version of the graphics card driver is present, then it may cause problems with Vue Rendering tool as it requires the latest version of drivers to work.
After updating your graphics drivers, when you restart OpenBuidlings Designer you should see that the Vue Rendering dialog is working as expected:
