| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): |
Connect Edition
| Environment: | Windows 10 (64-bit) |
| Area: | Class Editor Customization |
| Subarea: | N/A |
| Original Author: | Harshavardhan K, Bentley Product Advantage Group |
In OpenPlant Modeler CONNECT Edition, sometimes user needs to add a new associated item using Class editor . Alternate , option to add Associated Item is by using OpenPlant Project Administrator. ClickHere
- Launch Class editor for the desired WorkSet.
- Open OpenPlant.01.08.ecschema.xml from C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\Workspaces\WorkSpace\WorkSets\WorkSet Name\Standards\OpenPlant\Schemas.
- Click on search icon look type in Plant_BreakDown_Element and click on Goto. Now right click on Plant_BreakDown_Element, Add derived class and put the desired class name here, PROJECT_CODE
- Now OpenPlant_3D is schema is loaded and now right click to supplement the schema with OpenPlant_Supplemental Schema. Check the small gif clip.
- Click on search icon look type in Plant_BreakDown_Element and click on Goto. Now right click on Plant_BreakDown_Element, Add derived class and put the desired class name here, PROJECT_CODE.
Add Details as Below
- Right click on Project Code and add base classes, Add base Classes 1st from OPENPLANT Schema and 2nd from OPENPLANT 3D schema. See Image below and add accordingly Yellow Highlighted.
- Right click on Project Code and Add Custom Attribute >>> Business Key Specification from Custom Attribute option on the right.
- Right click on Relationship Classes and Add Relationship Class as below and then Add Constraints by clicking on class and add Project Code and Named Item respectively.
- Lastly, add PROJECT_CODE for Associated Item List For Equipment and add custom attribute for Project_Code as shown below in Green.
- Verify Results in OpenPlant Modeler, place an equipment and check the standard preference to see the Project Code added above.
communities.bentley.com/.../how-to-create-new-associated-property-using-class-editor-in-openplant-connect-edition
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
