| Version(s): |
CONNECT Edition 10.08.00.51 (Update 8) |
| Environment: | Windows 8.1/10 (64-bit) |
| Area: | Schema |
| Subarea: | Property |
| Original Author: | Aishwarya Kulkarni, Bentley Product Advantage Group |
In OpenPlant Modeler, requirement is to fetch the inside diameter of pipe. By default, configuration of OpenPlant Modeler, Inside Diameter of pipe is not populated. Attached below the snap for the same. This wiki article explains the procedure for it.
