| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): |
10.08.00.51
| Environment: | Windows 8.1/10 (64-bit) |
| Area: | Custom component |
| Subarea: | custom elbow |
| Original Author: | Shubham Sawant,Bentley Product Advantage Group |
In OpenPlant Modeler CE, the requirement is to create a custom elbow, let’s say 40 degree. By default, OPM can only place only 90 degree, 60 degree & 45-degree elbows as shown
This wiki article explains how to create a custom elbow of 40 degree.
- Launch Bentley Class Editor CONNECT Edition.
- For desired workset location, Select OpenPlant_3D.01.08 schema & click on Open to load the schema. Supplement the loaded schema with OpenPlant_3D_Supplemental_Modeling.01.08.ecschema & OpenPlant_3D_Supplemental_Information_3DComponent.01.08.ecschema
Refer the attached Wiki link to know, How to Load & Supplement Schema in Bentley Class Editor.
- From search button, search for Pipe Elbow Trimmed as shown
- Right-click Pipe Elbow class and select Add Derived Class option
- Add class name and display label according to the angle. For example, add Name as PIPE_ELBOW_40_Degree and DisplayLabel as Pipe Elbow 40 Degree for 40 degree pipe elbow.
- In Pipe Elbow class, Go to the OpenPlant_Physical Child_classes section. Right-click EC_Class_Name and select add element option. Add your class name in the EC_Class_Name array
- In custom angle pipe elbow class (created at step 4), Go to properties and select Angle property in your class. Click Custom Attributes... and select Add/Remove option.
- Add OpenPlant_Physical_Catalogue_Property_Map from custom attributes dialog. Make sure to set location as OpenPlant_3D_Supplemental_Modeling.01.08
- Add angle as ECExpression value in OpenPlant_Physical_Catalogue_Property_Map section. For example, Right click ECExpression > Add Element set its value to 40 for 40 degree pipe elbow.
- Right click your class and select Custom Attrubutes > Add/ Remove.
- Add Component Ports Information attribute from custom attribute dialog. Make sure to set location as OpenPlant_3D_Supplemental_Information_3DComponent
- Right click the Port Type and click Add Element twice.
- Add No. of Ports value as 2 & Add Port Type[0] value as MAIN_PORT and Port Type[1] value as RUN_PORT.
- Save the schema changes as shown
- Now, open the spec database for the desired workspace/workset from the below mentioned path
C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\Workspaces\WORKSPACE_NAME\WorkSets\WORKSET_NAME\Standards\OpenPlant\Specs
- Open the desired spec, let’s take mEX-OPM spec as an example.
- Open the Elbow table in database & new record of 40 degree. For example let’s filter the elbow of 100mm,copy the previous record, paste it below & edit the records as shown
- Save the spec & launch OpenPlant Modeler CONNECT Edition.
- place the pipe 100 mm of mEX-OPM spec
- As the direct tool is not available in the component gallery for the placement of 40-degree elbow, enter the key-in “ mechaddin place PIPE_ELBOW_40_DEGREE dsc=piping” as shown to place the same.
Note: To add the 40 degrees as a tool in the component gallery on the OPM interface, please have a look at the attached wiki link. Link >>
- Place elbow at the end of the pipe as shown
Notice that, the elbow of 40 degrees is placed successfully.
communities.bentley.com/.../how-to-add-dimensional-unit-to-added-property-in-openplant-modeler-connect-edition
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
