| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Part L |
In some instances, efficient display lighting cannot be selected as it will be greyed out.
The Display lighting options are only activated if a suitable room type has been selected.
The NCM database specifies what room types display lighting applies to. For example, selecting Retail > Display area (as below) will enable these options.
