| | Product(s): | OpenBuildings Energy Simulator | |
| | Version(s): | CONNECT Edition | |
| | Area: | Building Modelling | |
How to edit the window sill heights for the windows that are already placed in the model?
- At first, select any window in your model and open the Properties dialog box from the project tree as shown in the screengrab below.
- Upon opening the Properties dialog box, under Dimensions there is "Reference Point" Please change it as per your requirement (in this case I have changed it to Center/Top from Center/Bottom) and changed the Height as well. After that hit on Apply to make those changes.
- Finally, after making those changes, you can see in the model that the window sill height has been modified along with it. Please refer to the screengrab below.
