New and Existing Manufacturer based Raceway Catalogs in BRCM
Product:Bentley Raceway and Cable Management
Generation:CONNECT Edition
Version:10.10.00.xx
New Raceway Catalogs:
Manufacturer
Cable Tray
Cable Ladder
Cable Basket
Transit
·MKS-Magic 110 A2
·MKS-Magic 110 FS FT
·MKS-Magic 110 Unperforated FS FT
·MKS-Magic 110 Unperforated A2
·MKS-Magic 60
·MKS-Magic 85
·MKS-Magic 85 Unperforated
·SKS-Magic 110
·SKS-Magic 60 FS FT
·SKS-Magic 60 A2
·SKS-Magic 60 A4
·SKS-Magic 85
·SKS-Magic 85 Unperforated
·Marine Standard FS thk_1mm
·Marine Standard FS FT thk_1-25mm
·Marine Standard FS FT thk_1-5mm
·Marine Standard A2 thk_1-25mm
·Marine Standard A2 thk_1-5mm
·Marine Standard A4 thk_1mm
·Marine Standard A4 thk_1-5mm
·Marine Standard ALU thk_1-5mm
·Marine Standard ALU thk_2mm
·Walkable BKRS 100 FS
·Walkable BKRS 110 FS
·Cable ladder with trapezoidal rungs, light duty SG, FT, A2, A4, ALU
·Cable ladder with trapezoidal rungs, standard SG, FT, A2, A4, ALU
·Cable ladder with Z rung, light duty SG, FT, A2, A4
·Cable ladder with Z rung, standard Sg, FT, A2, A4, ALU
·Cable ladder LCIS 60, 6 m C30 FS, FT, A2, A4
·Cable ladder LCIS 60, 3 m C30 FS, FT
·Cable ladder LCIS 110, 6 m C30 FT
·Cable ladder SLCS 110, 6 m C30 FT
·Roxtec Transit Frame CF
· Roxtec Transit ComSeal Frame
·Roxtec Transit Frame GH
·Roxtec Transit Frame GH BG
·Roxtec Transit Frame GHM
·Roxtec Transit Frame HD
·Roxtec Transit Frame SBTB
·Roxtec Transit Frame SF
·Roxtec Transit Frame SFHM
·Roxtec Transit Frame SK
·Roxtec Transit Frame SRC R20
·Roxtec Transit Frame SRC R40
·Roxtec Transit round C RS T single cable
·Roxtec Transit round SLFR single cable
·Roxtec Transit round SLFR multi cable
·Roxtec Transit round SLFRS single cable
·Roxtec Transit round SLFRS multi cable
·Roxtec Transit round SLR single cable
·Roxtec Transit round SLR multi cable
·Roxtec Transit round SLRS single cable
·Roxtec Transit round SLRS multi cable
·MITA GRP CABLE TRAY 60mm HIGH
·MITA GRP CABLE TRAY 50mm HIGH
·MITA GRP CABLE TRAY 210mm HIGH
·MITA GRP CABLE TRAY GMAX POST SYSTEM
·MITA GRP CABLE TRAY GMAX CANTILEVER SYSTEM
·MITA GRP CABLE TRAY 110 HIGH
·MITA GRP CABLE LADDER GAL
·MITA GRP CABLE LADDER GXL
·MITA GRP CABLE LADDER GMLN
Existing Raceway Catalogs:
Manufacturer
Cable Tray
Cable ladder
Cable Basket
Conduit
·OBO Cable Tray MKS 35
·OBO Cable Tray RKS 35
·OBO Cable Tray DKS 60
·OBO Cable Tray EKS 60
·OBO Cable Tray IKS 60
·OBO Cable Tray MKS 60
·OBO Cable Tray MKSU 60
· OBO Cable Tray RKS 60
·OBO Cable Tray SKS 60
·OBO Cable Tray SKSU 60
·OBO Cable Tray RKSM 35
·OBO Cable Tray RKSM 60
·OBO Cable Tray DKS 85
·OBO Cable Tray MKS 85
·OBO Cable Tray MKS 110
·OBO Cable Tray SKS 85
·OBO Cable Tray SKS 110
·OBO Cable Tray SKSU 110
·OBO Wide Span Cable Tray WKSG 110
·OBO Wide Span Cable Tray WKSG 160
·OBO Cable Ladder LG 45
·OBO Cable Ladder SLG 45
·OBO Cable Ladder LG 60 NS
·OBO Cable Ladder LG 60 VS
·OBO Cable Ladder LG 110
·OBO Wide Span Cable Ladder WKL 110
·OBO Wide Span Cable Ladder WKLG 110
·OBO Wide Span Cable Ladder WKLG 160
·OBO Wide Span Cable Ladder WKL 200
·OBO Cable Ladder C40 1-sided
·OBO Cable Ladder C40 2-sided
·OBO Vertical Ladder LG 60 VS
·OBO Vertical Ladder SLL 60 CPS gel
·OBO Vertical Ladder SLM 50 C 40 FT
·OBO Vertical Ladder SLS 80 C 40 FT
·OBO Vertical Ladder SLS 80 W 40 FT
·OBO GR-Magic Mesh Cable Tray H-35 WD-39
·        OBO GR-Magic Mesh Cable Tray H-55 WD-39
·OBO GR-Magic Mesh Cable Tray H-105 WD-39
·OBO GR-Magic Mesh Cable Tray H-35 WD-48
·OBO GR-Magic Mesh Cable Tray H-55 WD-48
·OBO GR-Magic Mesh Cable Tray H-105 WD-48
·OBO C Mesh Cable Tray CGR
·OBO G Mesh Cable Tray Magic
·OBO Heavy-Duty Mesh Cable Tray SGR H-55
·OBO Heavy-Duty Mesh Cable Tray SGR H-105
·OBO Heavy-Duty Mesh Cable Tray SGR H-155
·RICO Cable Tray System 60
·RICO Wide Span Cable Tray System 105
·RICO Wide Span Cable Tray System 150
·RICO Cable Tray System 110
·RICO Cable Ladder System 60
·RICO Cable Ladder System 100
·RICO Wide Span Cable Ladder System 105
·RICO Wide Span Cable Ladder System 150
·RICO Wide Span Cable Ladder System 200
·RICO Cable Ladder C-Profile 30x15 SA 600, 3m & 6m
·RICO Cable Ladder C-Profile 30x15 SA 600, 6m
·RICO Cable Ladder C-Profile 40x22 SA 300, 3m & 6m
·RICO Cable Ladder C-Profile 40x22 SA 600, 3m
·RICO Cable Ladder C 40x22, perforated
·RICO Cable Ladder L 40x40
·PUK Cable Tray RGS 60 Steel
·PUK Cable Tray RGS 60 Galv
·PUK Cable Tray RG 60 Steel
·PUK Cable Tray RG 60 Galv
·PUK Cable Ladder LG 60
·PUK Cable Ladder LG 60 Steel & Galv
·PUK Cable Ladder LG 100
·PUK Cable Ladder LG 100 Steel, Galv & SS
·PUK Cable Ladder LGS 60 Galv
·Cable Ladder Wide Span Cable Ladder WPL 120
·Cable Ladder Wide Span Cable Ladder WL 120 Steel & Galv
·PUK Cable Ladder Wide Span Cable Ladder WPL 150
·PUK Cable Ladder Wide Span Cable Ladder WL 150 Steel, Galv & SS
·PUK Wide span cable ladder WL 200 Steel &Galv
·PUK Cable Ladder Vertical Ladder STU 50
·PUK Cable Ladder Vertical Ladder STU 50 Steel, Galv & SS
·PUK Vertical ladder STU 60 Galv
·PUK Vertical ladder ST 81 Galv
·PUK Vertical Ladder ST 82 Hot-Dip Galvanized
·PUK Cable Basket G 50 Steel
·PUK Cable Basket G 50 stainless steel
·PUK Cable Basket G 50 Galv
·ElectroLink Cable Tray C Series
·ElectroLink Cable Tray I Series
·ElectroLink Cable Tray P Series
·ElectroLink Cable Tray R Series
·Hotex Cable Tray Heavy Duty Return Flange Perforated
·Hotex Cable Tray Light Duty Straight Flange Perforated
·Hotex Cable Tray Heavy Duty Straight Flange Perforated
·Hotex Cable Tray Medium Duty Return Flange Perforated
·Hotex Cable Ladder Heavy Duty 125
·Hotex Cable Ladder Light Duty 50
·Hotex Cable Ladder Medium Duty 100
·Cable Tray SPM
·Cable Tray MRF Heavy Duty
·Cable Tray SRF Heavy Duty
·Cable Tray SSL Heavy Duty
·Cable Tray XRF Heavy Duty
·Cable Ladder Emerald
·Cable Ladder Cable Ladder Sapphire
·Cable Ladder  Cable Ladder Topas
·Legrand Electroplated Zinc Cable Basket
·Cable Basket Electroplated zinc
·Cable Basket Electroplated galvanised
·Cable Basket Electroplated stainless steel
·Metsec Cable Tray HD HDG
·Metsec Cable Tray HD PG
·Metsec Cable Tray HD SS
·Metsec Cable Tray LD SS
·Metsec Cable Tray LD HDG
·Metsec Cable Tray MD SS
·Metsec Cable Tray MD HDG
·Metsec Cable Tray MD PG
·Metsec Cable Tray LD PG
·Metsec Cable Trunking
·Metsec Cable Ladder UHD HDG
·Metsec Cable Ladder UHD SS
·Metsec Cable Ladder HD HDG
·Metsec Cable Ladder HD SS
·Metsec Cable Ladder LD HDG
·Metsec Cable Ladder LD SS
·Cable Ladder KHZ
·Cable Ladder KHZP
·Schneider Cable Ladder GRP Type GAL
·Schneider Cable Ladder GRP Type GHL
·Schneider Cable Ladder GRP Type GMLN
·Schneider Cable Ladder GRP Type GNLN
·Schneider Cable Ladder GRP Type GXL
·Schneider Cable Ladder WIBE Type KHZ
·Schneider Cable Ladder WIBE Type KHZP
·Schneider Cable Ladder WIBE Type KHZPS
·Schneider Cable Ladder WIBE Type KHZPV
·Schneider Cable Ladder WIBE Type KHZSP
·Schneider Cable Ladder WIBE Type KHZSPZ
·Schneider Cable Ladder WIBE Type KHZV
·CableBasket CF
·Rehau Plastic Conduits
·Rehau Steel Conduits
·Conduits PVC Schedule 40 Conduits 16-103
·Conduits PVC Schedule 40 Conduits 129-155
 Conduits PVC Schedule 80 Conduits 16-103
·Conduits PVC Schedule 80 Conduits 129-155
·Conduits Electrical Metallic Tubing EMT
·Conduits Intermediate Metal Conduit IMC
·Conduits Galvanized Rigid Conduit GRC
·Conduits Kwik-Couple Galvanized Rigid Conduit
·Cooper Series 1 Steel Cable Tray
·Cooper Series 1 AL Cable Tray
·Cooper Non-Ventilated Series 34 Stainless Steel
·Cooper Series 1 Steel Cable Ladder
·Cable Ladder Series 2, 3, 4 and 5 Steel
·Cable Ladder Series 3 and 4 Stainless Steel
·Cooper Ventilated Through Series 34 Stainless Steel
·Cable Ladder Series 2, 3, 4 and 5 Aluminum
·Ventilated Bottom Series 1 Steel
·Cooper Ventilated Through Series 2345 Steel
·Vented Through Series 2,3,4,5 Aluminium
·Non-Ventilated Trough Series 2345 Steel
·Chalfant Steel Cable Tray
·Chalfant Steel Cable Ladder
·Cable Ladder Aluminum
·Thomas And Betts Aluminum Cable Ladder
·Thomas And Betts Steel Cable Ladder
·Thomas And Betts Aluminum Ventilated Cable Ladder
·Thomas And Betts Steel Ventilated Cable Ladder
