User Defined Attributes (UDA) Settings - Bentley Raceway and Cable Management CONNECT Edition
If you have custom point data that does not match the existing properties available, you can define your own properties according to your company's standards.
Bentley Raceway and Cable Management allows the user to define UDAs for raceways, equipment, cables through the UI or you can import the UDAs through Excel import.
You can follow the below given articles to learn more about the User Defined Attributes(UDAs):
 Index
  1.  How to Create an Overwrite for 3D Cable Visualization.
  2. How to Create a Cable UDA in Bentley Raceway and Cable Management CONNECT Edition.
  3. How to Create Equipment UDA in Bentley Raceway and Cable Management CONNECT Edition.
  4. How to Create Raceway UDA in Bentley Raceway and Cable Management CONNECT Edition.
  5. How to Import Cable Types in Bentley Raceway and Cable Management CONNECT Edition.
  6. How to Import Cable Voltage Levels into Bentley Raceway and Cable Management CONNECT Edition.
  7. How to Import Equipment UDAs using Equipment Import Tool.
  8. How to import Cable UDA using Cable list import tool
  9. How to configure UDA settings for Raceway Labels.
  10. How to display raceway UDA on element information
 External Links
Check Video Content - Bentley raceway and Cable management Tech Tips
Bentley Sign In
learn.bentley.com
Access your Bentley Services
 Comments or Corrections
Bentley's Product Advantage Group requests that you please confine any comments you have on the Wiki entries to this "Comments or Corrections?" section. THANK YOU!
