Components Center - Bentley Raceway and Cable Management CONNECT Edition
Components Center is a platform for publishing component catalog or component part libraries and using them in your projects. The catalogs can be published by manufacturers, Standard bodies, and content aggregators. For example, 3D models of Industrial or Architectural components, 2D electrical symbols or databases containing dimensional and electrical properties from a manufacturer's catalog. Components Center provides a platform to consolidate all these disparate catalogs in a single location.
The Components Center uses the Bentley Cloud Service to store catalogs. In the Project Portal, you can use the Components Center to add components required for your project. These components can be leveraged by any members of your ProjectWise Project using the Components Center Explorer.
 Index
  1. How to Create Cell-based Equipment and Publish it on Components Center
  2. How to Place Cell-Based Equipment from the Components Center
  3. How to Create a new Catalog and add Components to It through Components Center’s Web Portal
 External Links
Check Video Content - Bentley raceway and Cable management Tech Tips
Bentley Sign In
learn.bentley.com
Access your Bentley Services
 Comments or Corrections
Bentley's Product Advantage Group requests that you please confine any comments you have on the Wiki entries to this "Comments or Corrections?" section. THANK YOU!
