What's New in Bentley Raceway and Cable Management CONNECT Edition Update 1
Product(s):Bentley Raceway and Cable Management
Version(s):10.01.00.21
Environment:N/A
Area:N/A
Subarea:N/A
What's New Highlights
Automatic routing line placement between cable trays and conduits
 The Automatic routing lines placement improves efficiency by:
New Cross Section Template for the details Serial No, Cable Number, Cable type, Size and Weight
New Supported Platforms
Separate parts on BOQ report by product code
Raceway ID: includes leading zeros in Start Value
Enabling OpenPlant Supports Engineering module
