| Defect Number | Description |
| 173590 | Raceway Offset function crashes, if catalog data is not set to double |
| 173469 | Unit parameter in SPEC_CableDrums.xml is ignored |
| 352532 | 3D Cable visualization results in improperly displayed and entangled 3D cables. |
| 202723 | 3D cable visualization is not created for manually routed cables |
| 194470 | Raceway routes in wrong direction with placed part Hinge |
| 727374 | The direction that conduit routes after placing Conduit Left/Right Tee is not aligned properly with the Tee with certain parts |
| 473528 | Cable Status is not imported when importing through the cable list. |
| 576340 | DUCTBANK_ENVELOPE inherit STRUCTURAL_COMPONENT in place of DUCTBANK_ITEM |
| 307338 | Material Thickness cannot be edited in the Edit Raceway catalog dialog without getting an input string error. |
| 560254 | 3Dconexxion Spacemouse losses focus while using visualization tool inside Cable Manager |
| 603589 | Vertical Tee does not have Bend radius selection for Generic Cable Ladder. |
| 620461 | Update 9 Russian build will crash after opening user's custom file. |
| 600200 | Check Raceway Connectivity tool took long time and seemed to go unresponsive in more complex models. |
| 360292 | [Raceways] BRCM Crashes on placing raceways with zero offset |
| 422462 | Crash when Ductbank/Conduit fitting is inside Manhole wall and you try to route from there |
| 422592 | Using Components Center and attempting to place a Motor resulted in an error that no variations were found. |
| 503835 | Cable Type import allows invalid units to be imported and 3D cable is not created for the cable types with invalid units. |
| 517520 | Using the Chinese dataset the automatic part placement could not generate crossovers in certain catalogs |
| 605328 | PowerPlatform | Construction class toggle is also turning off the display of Primary element class components |
| 459037 | [Russian] Status of the raceway in properties and equipment doesn't match |
| 381043 | [Integration with OPM] Contextual Ribbon appears even if BRCM is uninstalled |
| 381274 | Unable to use Bentley Raceway and Cable Management for a V8i OPM Migrated WorkSet |
| 527301 | BRCM Crashes when using the Navigation Tool from the RCMNAVIGATIONTOOLBYCONTEXMEN key-in |
| 530266 | Open the Raceway Generator and randomly clicking on System or Catalog selection could result in an unhandled exception. |
| 536967 | Duplicate cable entries could appear in the Options > Cable Types if the cables are arranged with respect to cable Names and you edit any Property. |
| 537062 | [iTwin] Pushing i.dgn or dgn file in through iTwin Synchronizer gives a warning message that the synchronization completed with issues. |
| 554141 | The software could crash using the Navigation Tool when selecting an item, filtering, and navigating. |
| 585881 | In the Russian version all raceway properties switch to English after 2-3 starts of the software. |
| 577728 | Wrong raceway fill info appears in routing model after making a change in raceway information. |
| 634282 | Space Allocation size was missing from the BOQ |
| 697779 | Some Raceway elements are listed in Explorer which are not modeled/available in the dgn file. |
| 615826 | File size increases substantially after creating 3D cables |
| 576054 | Routing Filter in the Cable Manager is not working while AutoRouting cables |
| 594671 | Creating 3D cables is very slow |
| 554909 | Replace Imperial Sample Project's AREP database export file with the attached one to ensure more cables get auto routed. |
| 590374 | Raceway routing is slow and has considerable lag in large raceway models. |
| 594018 | Opening and Closing Pre-Check Auto Routing Entry Points takes considerable time in large models. |
| 724826 | AutoPlant objects display incorrect profile inside BRCM - need updated AutoPlant object enablers to resolve the issue. |
| 542486 | There are cable crossing after generating 3d cable |
| 669078 | 2D Extraction for custom cell based equipment is different from the 2D cell graphics defined for the equipment. |
| 606889 | The software crashes when adjusting the view brightness settings. |
| 757846 | Explorer lists some raceway items which do not have any graphics and cannot be deleted. |
| 745117 | The software crashes on Launching Material Editor |
| 635767 | Raceway Generator creates gaps in Cable Routes |
| 664983 | 3D Cable creation Ignores Air Gaps |
| 609593 | Attempting to load the Light Manager would crash the software |
| 746733 | Unhandled exception error is displayed while saving changes in ID Manager. |
| 715525 | 3D cable visualized with routing line on supports does not have curved ends. |
| 585750 | Using the Cable Manager, 'Undefined Cable Type' Message appears in the message center for successfully routed cables |
| 600781 | In the Raceway Router the 'Logical snap to rw parts' Toggle can't be turned off |
| 709347 | Changing Register type of Documents in the Document Manager doesn't update which ribbon tools are loaded when the file is opened |
| 739927 | The example project's cable list imported some invalid records created in database |
| 776230 | When you attempt to edit an existing Equipment and change it to another type of equipment it would not properly update |
