| Product(s): | Bentley Raceway and Cable Management |
| Version(s): | 10.03.00.25 |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
Components Center is a cloud-based digital component library and catalog management service. It allows users to efficiently manage their digital component libraries while providing their designers with approved, proprietary components as well as manufacturer's content via subscriptions.
Components Center users can create their own organization catalogs and populate them with content provided by Bentley or upload custom content to share among all their users.
Both Raceway and Equipment can be downloaded from Components Center. The first time a raceway is routed or an equipment placed, the catalog will be downloaded to a local cache folder making it faster to insert the next time you route raceway or place equipment.
We now include raceway cable fill information in i-models so that the information can be reviewed in Navigator.
You now have the ability to set the same level for equipment and equipment IDs in the Options > CAD Standards > Levels dialog.
You can now display the position of any raceway as defined in the grids of the Duct Bank or Raceway Router dialogs in Raceway ID labels. i.e. "A1" would represent a position defined by column "A" and row "1" in the routing dialog.
The following tools now allow you to include the "Position" attribute in the ID Settings:
This new API allows you to specify an equipment name and position to automate the placement of equipment.
public Equipment. PlaceStatus Place(
string eqiupmentID,
double x,
double y,
double z
When creating a new project in the Project Manager the software will now create the DGN folder and place the rcmProject.xml file in this folder.
