| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Installation and Licensing |
The Daylighting simulations in OpenBuildings Energy Simulator utilise the lighting simulation engine "Radiance".
Radiance is non-Bentley software so should you need to download a copy which can be obtained from the Radiance website:
https://www.radiance-online.org/download-install
Proceed though the installation, leaving all settings as default.
Once complete you can run Daylighting Simulations to analyse daylight factors, or daylight visualisation.
