Error ‘macro syntax error’ appears while generating Isometric Drawing in OpenPlant Isometrics Manage
Product(s):AP_OPIM  CONNECT Edition
Version(s):10.XX.XX.XX
Environment:Windows 10 (64 bit)
Area:Error, Logs, Messages, Crashes
Subarea:
Original Author:Abhijeet Shinde, Bentley Product Advantage Group
While working with AutoPLANT Modeler and OpenPlant Isometric Manager CE, user may below error message while generating the isometrics drawing. This wiki article explains the steps to resolve this issue.
This errors generally appears when user creates the incorrect the Spool numbering sequence for welds, pipes, etc in the style.cfg file.
Steps to Resolve
Comment out the highlighted variable from style.cfg file as shown in below snapshot
communities.bentley.com/.../autoplant---openplant-isometrics-manager-connect-edition
Still a Problem?
Comments or Corrections?
