| Product(s): | Bentley Raceway and Cable Management CONNECT Edition | |
| Version(s): | CONNECT Edition | |
| Environment: | N/A | |
| Area: | Installation_Configuration | |
| Subarea: | N/A |
In the CONNECT Edition, the software utilizes the native Power Platform configuration system to locate the dataset, connect to the project database, and specify various default settings.
Note: Power Platform is the MicroStation core application that underlies the CONNECT Edition product.
New configuration variables have been introduced that can be set in any configuration file to configure the software. The purpose of this article is to provide a comprehensive list of the application specific variables that are used to configure the software and explain their purpose.
Application variables are prefixed with “BRCM_” to set them apart from the standard Power Platform variables.
The following table provides a complete list of the application specific variables and explains their purpose:
Name |
Operator |
Value Type |
Value (typical) |
Description |
BRCM_APPLICATION |
String |
BRCM |
Short name of the application |
BRCM_DB_CONNECTSTRING |
String |
DSN=BRCMUSER;UID=BRCMUser;PWD=BRCM |
Connection String for SQL Server Database. |
BRCM_DB_ID |
String |
MYWORKSET |
Prefix given to the SQL table names which typically matches the WorkSet name. |
BRCM_DB_STATIONID |
String |
$(computername) |
Unique work station ID. |
BRCM_DIR |
C:\Program Files\Bentley\Bentley Raceway and Cable Management CONNECT Edition\BRCM\ |
BRCM_FILE_UPDATE_OPTION |
1 |
Controls how data is saved to the database when the design file is closed (0: no update, 1: Prompt to update, 2: silent update) |
BRCM_IMODEL_PUBLISH_MODE |
0 |
Not used in CONNECT Edition |
BRCM_WS_EQUIPMENT |
String |
C:\ProgramData\Bentley\BRCM CONNECT Edition\Configuration\Workspaces\BRCM Metric Example\Standards\BRCM\std_dataset\equipment |
Location of equipment data files |
BRCM_WS_LANGUAGE |
String |
EN |
Language Code for localized metadata files |
BRCM_WS_METADATA |
String |
C:\ProgramData\Bentley\BRCM CONNECT Edition\Configuration\Workspaces\BRCM Metric Example\Standards\BRCM\std_dataset\metadata |
Location of metadata files. |
BRCM_WS_RACEWAY |
String |
C:\ProgramData\Bentley\BRCM CONNECT Edition\Configuration\Workspaces\BRCM Metric Example\Standards\BRCM\std_dataset\raceway |
Location of raceway data files. |
BRCM_WS_RACEWAY_TEMPLATES |
String |
C:\ProgramData\Bentley\BRCM CONNECT Edition\Configuration\Workspaces\BRCM Metric Example\Standards\BRCM\std_dataset\raceway\Templates |
Location of raceway templates. |
BRCM_WS_SCHEMAS |
String |
C:\ProgramData\Bentley\BRCM CONNECT Edition\Configuration\Workspaces\BRCM Metric Example\Standards\BRCM\std_dataset\schemas |
Location of EC schema files. |
BRCM_PW_SUBFOLDER_CPC |
String |
\Cable Pull Cards |
Project subfolder for cable pull cards |
BRCM_PW_SUBFOLDER_REPORTS |
String |
\Reports |
Project subfolder for reports |
BRCM_IMAGE_PATH |
String |
C:\ProgramData\Bentley\BRCM CONNECT Edition\Configuration\Workspaces\BRCM Metric Example\Worksets\BRCM_EU_EN\Standards\BRCM\Reports\Images |
Location of the cable routing path images. |
BRCM_OPM_CABLE_CONNECTION |
String |
ELECTRICAL_DEVICE_OFFSET |
X,Y,Z Offset from the insertion point of the OPM equipment for electrical device. |
BRCM_USER_DEFINED_CONFIGS |
String |
$(APPDATA)/Bentley/$(BRCM_APPLICATION)/userconfigs/ |
As a BRCM administrator, you can now define custom ID, Raceway, and Duct Bank spacer configurations and adjust a configuration variable to control where these configurations are saved making it more convenient for you to control who has rights to modify them. The variable, BRCM_USER_DEFINED_CONFIGS by default is set to the local user's app data folder, but can be changed as you desire. |
BRCM_ENABLE_EC_PROVIDER |
0 |
Disables the EC Provider that populates the list of cables in the Explorer by querying the SQL database. | |
BRCM_DB_TYPE |
iTwin |
PlantSight Integration (Technical Preview). | |
BRCM_ITWIN_IMODLE_NAME |
'iModelName |
BRCM_ITWIN_CACHE_PATH |
= | String |
D:/BRCMiModelCache |
PlantSight Integration (Technical Preview). Specifies the location of cache folder. |
These configuration variables can be set in any configuration file. To understand how these variables are used in the configuration files that are delivered with a default installation of the software, please refer to the Configuration Files article.
