| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Part L |
When running a PartL calculation you may come across the following error:
This error occurs if a room has been selected on the Select Rooms tab, but then not assigned to a HVAC zone on the HVAC System tab, and also on the Room Data tab.
To do so, please ensure that the room's zone is included as shown below:
Then, on the Room Data tab please go into each room and specify the HVAC:
