| Product(s): | OpenPlant Modeler CONNECT Edition Update 8 |
| Version(s): |
10.08.00.51 |
| Environment: | Windows 10 (64-bit) |
| Area: | Schema Customization |
| Subarea: | PlantSight Integrated WorkSet |
| Original Author: | Deepak Singh, Bentley Product Advantage Group |
In OpenPlant Modeler, requirement is to know about, how to update existing customization for a PlantSight enabled workset.
Upon Associate & Schema provision for OpenPlant Modeler workset all the configured schema changes pushed to iModel of PlantSight project. During the course of time based on project requirement, requirement is to update the existing customization. In the wiki article, we will consider case of Equipment tag name. During provision, equipment tag name has name format as DEVICE_TYPE_CODE "-" NUMBER. Same tag name for equipment can be seen in PlantSight Visualizer as shown below.
In this wiki article, we will learn how to add additional property for tag name & reflect the same in PlantSight Visualizer.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
