| Product(s): | PlantSight |
| Version(s): | |
| Environment: | Windows 10 (64-bit) |
| Area: | .Pod file format |
| Subarea: | N/A |
| Original Author: | Ashutosh Patil, Bentley Product Advantage Group |
This wiki will help in loading .pod file format through iModel into PlantSight for design review.File considered are here used as sample to test.
communities.bentley.com/.../reality-data
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
