OpenPlant PID Key-ins
Product(s):
OpenPlant PID
Version(s):
Connect Edition | 2024 & Above
Environment:
Windows 11 (64 bit)
Area:
General
Subarea:
Maintenance
Original Author:
Rahul Kumar, Bentley Global Technical Support Group
Various Key-in for OpenPlant PID
In this Section, the following key-ins are available in OpenPlant PID and can be used to perform various updates.
Various Key-ins
Key Ins  Description
pid annotation recreate  Initiates recreation of annotation command
pid annotation redraw all  Initiates the annotation to redraw command
pid annotation redraw selected  Initiates the selected annotation to redraw command
pid assembly create  Initiates the create assembly command
pid assembly insert asassembly  Initiates the insert assembly command
pid assembly insert asindividual  Initiates the individual assembly command
pid assembly manage  Initiates to open manage dialog for assembly command
pid BatchConvert
pid component annotate  Initiates the component to annotate command
pid component assigntemplate
pid component assigntemplate invalid
pid component assigntemplate notYetValidated
pid component assigntemplate valid
pid component build manage
pid component build wizard
pid component ChangeLineType
pid component ChangeLineType instrumentLine
pid component ChangeLineType pipeline
pid component ChangePiperunToNewLine
pid component ClearECProperties
pid component cloud add
pid component cloud remove
pid component connectpoints
pid component connectpoints hide
pid component connectpoints show
pid component create
pid component dump
pid component releaseTags
pid component redraw all
pid component redraw cells
pid component redraw selected
pid component replace
pid component resetCellScale all
pid component resetCellScale selected
pid component scale reset
pid component scale set
pid component Select
pid component Select ByElementId
pid component Select ByGUID
pid component Select ByInstanceId
pid component Select ByPEP
pid component RelateInstrumentsToPanel
pid component VirtualInstrumentTool
pid component ReplicationTool
pid conform component
pid conform instrumentline
pid conform piperun
pid conform cellsAutomatically
pid conform cellsAutomatically showEditor
pid diagnostic CheckForDuplicateGUIDs
pid diagnostic CheckSsSixPageConnectors
pid diagnostic delete CorruptComponents
pid diagnostic delete OrphanedLogicalGroups
pid diagnostic fix componentPoints
pid diagnostic fix corruptRelationships
pid diagnostic fix documentRelationships
pid diagnostic fix runConnectPoints
pid diagnostic UpdateComponentGUID
pid diagnostic ValidateRelationships
pid insert
pid Join
pid Join remove
pid logMode batch
pid logMode interactive
pid loop AddComponent
pid loop RemoveComponent
pid model delete CorruptComponents
pid model delete OrphanedLogicalGroups
pid model delete ClearOrphanedPBSItems
pid model export drawing
pid model export ECXML
pid model export publishOpenPlantIDgnToOwl
pid model fixDocumentRelationships
pid model import drawing
pid model import idgnlist
pid model import owllist
pid model refreshProperties
pid model refreshpbsproperties
pid model regenguid
pid model releaseTags
pid model resetReservedFlag
pid model regenerateGUID
pid model settings
pid model standardPreferences
 pid model LaunchAhaPortal
pid model refreshstandardPreferences
pid model ResetStandardPreferencesDialog
pid model validate
pid model validate showResults
pid model validateAlternateRepository
pid model execute
pid OpenPlantSpecs selectProvider
pid piperun ChangePipeline
pid piperun Create
pid piperun InteriorVertexHandle add
pid piperun InteriorVertexHandle slide
pid piperun JumpComponents
pid piperun Merge
pid piperun Split
pid piperun UpdateToFrom
pid piperun ValidateBreaks
pid PlantProject assignUniqueKeys
pid PlantProject disassociate
pid PlantProject refreshlocaliModelcopy
pid PlantProject ReIssueiTwinBriefcase
pid PlantProject reuse
pid PlantProject settings
pid PlantProject sync
pid PlantProject syncdirection
pid PlantProject syncdirection AlwaysAsk
pid PlantProject syncdirection DbToDgn
pid PlantProject syncdirection DgnToDb
pid PlantProject synconstartup
pid PlantProject workoffline
pid PlantProject OpenPlantSight
pid PlantProject OpenProjectPortal
pid relationship create
pid relationship remove
pid ShowRSSFeed
pid xmlReporttoDgnLib
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Knowledge Base Article entry to Forum section. THANK YOU!
