Resolved Issues in OpenPlant PID CONNECT Edition, 10.11.00.213
Product(s):OpenPlant CONNECT PID Edition Update 11
Version(s):
10.11.00.213
Area: -
Subarea: -
Original Author:-
BUG DetailsDescription
175915OPPID V8i - Error is generated in message center if non assembly dgn is opened in managed workspace from assembly manager
177863OPPID CE Update5- Pipe Run Page Connector sequence number is not updated in Explorer when edit via explorer
178140OPPID_V8i : Custom linestyles (Bi-Colour) representation shows discontinuation during directional changes.
178258OPPID CE U3: Annotation Update Doesn't Work in OpenPlant PID
178893OPPID CE Update 1:unable to create assembly of components that include insulation break
178895OPPID CE Update 1:  file upgrade -error on creating assembly involving different specs
178915OPPID CE Update 1: workspace upgrade - Component manager -> "Workset Alert" dialog on selecting create or edit annotations
178939OPPID update 1 to iModel Hub: Browse option is not working properly
178940OPPID V8i-Using Text Style's Shx Big Font as gbcbig, changes special characters like ü ö ä to question marks
178964OPPID CE Update 1: PW Managed workspace :- exception on creating two assemblies of same name
178972[Automation] : PID_Cannot place some of the instrument function elements using key in.
179011OPPID_CE | Component Manager Doesn't Retain Defined Color For Tool
179055OPPID to iModel Hub: 'Confirm Component deletion from iModelHub' Dialog doesn't appear if components are deleted by other user in multiuser scenario when  "IMODEL_SYNC_DELETECOMPONENTS=2"
179486OPPID CE : Internal Reports -> Column title not updated on changing property name
179639OPPID- PW Integration- mcm.dll error is displayed on launching OPPID SS6 R2 with PW in environment from desktop
179660OPPID CONNECT Edition: 'Alarm Limit' of Instrument Property is Not Updating in Post Initial Insertion in CE
179677OPPID Master Units should be changed for our default Metric Project to millimeter and inches for the Imperial Project
255054[PlantSight] - Relationship is added for Orfice Plate on sync
270348[Plant Sight] - Inline flow elements are listed in differencing dialog, each time after sync
272283OPPID_CE_U7: Placing an assembly created in V8i with an orphaned pipe run should prompt the user that a pipeline is required.
280183OPPID_U7 : "CODE VALUE" is not showing for Instrument list in PlantSight.
294580OPPID- Error on pasting annotation from component clipboard
295312OPPID_CE: Property does not cascade from one instrument to another in OpenPlant PID
302108Issue Resolution Service (Manage Issues) - Error on editing issue from OPPID
386316[OPPID_CE]: "BESM About" Command in Key-in is crashing OPPID
460553OPPID CE Update9- BMF_JIT_VALIDATION doesnt seem to update Validation check box
478512OPPID CE U9- Document reserve error on trying to synch copied document
480755OPPID CE U9 - Area is displayed as "?" in tag creation dialog, when tags are displayed from PlantSight
506807[OPPID CE U9]: Unhandled exception appears if we close the workset and then open different unit workset in same session
527762OPPID CE U9- Link Selected and Link All buttons in Model Validation dialog should be grayed out in work-offline mode
528869Incorrect cel file Unit is Observed in Metric & Imperial workset of Default Workspace.
533088OPPID CE U9 - Component annotation does not get updated when area is renamed from Explorer -> Properties
539896EDM_OPPID - Tag name is not updated in EDM after changing the Plant Area name from OPPID
540936OPPID CE U9 - WBS items changes to none if any WBS item is selected in Properties dialog
574074When placing the  figure 8 blind flange then pipe run is merge with valve.
576395EDM_OPPID - Differencing dialog is coming in empty when sync operation is performed from Plantsight to drawing
600831OPPID CE U10- To/From data is not getting populated for P&ID Split Workflow
622394OPPID CE_U9:  Adding Calculated ECproperty specification  custom attribute for NOMINAL_DIAMTER on Pipeline throws failure value for Imperial workset but not for Metric workset.
662020OPPID CE U9 - Conformed Equipment and pipeline is shown in differencing dialog, on every sync
686339OPPID CE U10 - Changing Area to none, changes equipment annotation to Equipment in drawing but does not update in Properties and Differencing dialog.
686873OPPID CE U10 - No "no difference found" message appears on syncing file for the second time,when user sync document which was created in offline mode
714322OPPID_CU9: Unable to sync Extruder and Scale classes to PlantSight in standard setup
730306OPPIDCE U9 can not update the existing properties of component, which was assigned by DBQUERY
737877OPPID CE U10 - Error on sync after syncing sheet model
738965Instrument Line doesn’t show correct input and output values
774131OPPID CEU10- Cloud commands doesn't work from Annotate Tab
784041OPPID CE U10 - Annotation of Valve is not getting updated after using PageConnector options of Connect to Existing
792116OPPID CE U10 -D-3D  Area of Equipment changes to none, on syncing PlantSight to Drawing
792363OPPID CE U10 - Valve state property is blank if valve tag is placed from Tag Browser dialog
792467OPPID CONNECT Custom Display Name for Auto Nozzle List not working as designed
794521OPPID CE U10 -PW - No file modification  appears on opening file, which is dragged and dropped in PW directory
798067OPPID CE U10 - V8i Upgrade - Invalid specs are present
798105OPPID_CE_U9_Annotation Color Setting not honored
798397OPPID CE U10 - Annotation - Annotation is not updated if component is edited from Properties
800001OPPID CE U10 - Exception on moving components, having connected nozzle in free space
800466OPPID CE U10 - Relationship of nozzle gets broken, if nozzle is dragged over pipeline
804192OPPID CE U10 -Placement of Control Valve is incorrect, if Actuator type is changed after valve placement
805923OPPID CE: SEGMENT_TERMINATION_ALT1 does not populate Piperun To or From
867697OPPIDCE_U10: Line jumper not working when different pipelines cross each other.
871565OPPID CE U10 - Incorrect Source class name in MappingsTagClass.json for Instrument Loops
874188OPPID CEU11- Leader Line is not getting placed with parametric instruments
875653OPPID_CE_U10_Sync WBS button not working as expected
902450OPPID_CE_U9.1 : Copied drawing GUID is not getting updated automatically when working in Projectwise + Plantsight integrated environment
930591OPPID_CE : Pipe_End_Jumper is not working
936862"Codespec is Invalid" Error when syncing with Plantsight for all classes under SIGNALLINE
945629OPPID CEU10.1- Application crashes on dragging components(Instruments/Pipe Lines/Valves)
978384OPPID CEU11- Piping Utilities is present at incorrect place in the Interface in ISO workset
981570OPPID CE U11- Iso workset- Error messages while placing valves on pipe line
984483OPPID | When placing reducers in the pipeline the to-from data is lost
986822OPPID CEU11- Please enter comments dialog is still displayed on synch drawings in batch mode
990266When one of the parts of a pipeline tag is changed (Unit, System, or Train), the valves and inline components on that pipeline are renumbering automatically in custom schema
996104OPPID_PS_CE - Browse Dialog window keeps scaling up when creating a pipeline and using Browse each time
997619Open Microstation drawing in OPPIDCE_U10 displays irrelevant Conversion Error Log  message
1018657OPPID CEU11- Instrument Line is left behind on moving components
Please also visit Release Announcement Page for highlights of the release.
