The following items summarizes the latest fixes in the OpenPlant Modeler CONNECT Edition Update 11 release. We have included the list of fixes for OpenPlant Project Administrator, OpenPlant Isometrics Manager, OpenPlant Support Engineering as well.
OpenPlant Modeler - Update 11 - 10.11.00.260
BUG Details | Description |
178069 | Improper orientation of Supports, which is placed on a vertical sloped pipe |
178692 | The length of nozzle cumulatively adds up upon editing in Nozzle Manager when the Nozzle is placed axially on top. |
179088 | Components of piping gallery gets displayed when spec filter is enabled and apart from cablet any other specs is selected |
179151 | Spec Filter is also filtering out those components which can be placed with similar specification when spec filter is off |
179379 | OPM- On Sloped Pipe Support is Slightly Rotating |
179738 | Branch pipe penetration inside the header pipe is same for RBR\UBR Stub On and Set In connections |
202941 | OPM gets crashed while setting up background maps |
266882 | ‘Unhandled Exception’ appears on selecting Newly defined Datum in ‘PlantSight Differences’ dialog |
277571 | Engineered Support tab missing from OPM toolbar after installing with enabled OPSE option |
291906 | View switches from Top to Default on placing freeform nozzle on Equipment [intermittent behavior] |
292067 | Mapping Configuration Editor Doesn't Show Related Class For Custom Created Class |
317160 | RSS feeds unable to load |
520271 | Solid area settings mismatch for new MSTN imperial seed files |
535387 | Lapjoint Flange Hub's thickness are not as per Std Dimensions |
540701 | Part 1 - Incorrect BOM of Gasket & Fasteners in Isosheets due to Joints relationship are not getting updated in OPM Export data after using Manage Joint Associations . |
595389 | "Reducing Slip on Flange" and "Reducing Threaded Flange" Graphics needs to be Updated |
632259 | Move component is not consistent with accusnap |
650987 | OPM get crashed having OPSE supports placed upon check-in/check-out 2 to 4 times through explorer |
694801 | Incorrect placement of Note, when placed on slope/inclination of pipe. |
729004 | "Element Description" for Welds, Gaskets and Bolts appears "OPM Component" in a new dgn created from with in a dgn |
762098 | OPSE support components are not updated to PlantSight after first check-in |
769864 | In Autofitting and Allow Misaligned Fittings UBR intersection is not correct. |
772956 | Valve and Topwork is not rotating simultaneously. |
785916 | OPM crashes when attaching itwin references in BRCM enabled workset |
809283 | OPM_PS - All 'Interoperability' commands are failing, loading 'Deactivate' dialog instead |
834020 | Modifying any of the free commands through 'Structural Properties' is not possible when license is not activated |
859498 | Modeler crashes on selecting 'New' icon or browse to load existing dgn via Workpage dialog |
864671 | Unhandled Exception error is displayed while modifying equipment using Modify Component tool. |
866614 | Gaskets and Bolts are not placed automatically on Weldneck Flange when connected on a copied pump. |
868679 | Gridlines.txt is not generating on creating/updating grid models |
868691 | Incorrect Joint is Created with Pipe & Elbow Mechanical Female Ends. |
868711 | “DWG Workset Wizard” section is incorrectly displayed under Workspace dropdown in OPM Workpage dialog |
869064 | Part 2 - Incorrect BOM of Gasket & Fasteners in Isosheets due to Joints relationship are not getting updated in OPM Export data after using Manage Joint Associations . |
869086 | OPM crashes while placing Eccentric Reducer |
881353 | Issue created on PlantSight is not visible in "Manage Issue" |
893103 | Support locator placement is not correct on pipe slope. |
911022 | Auto Branch/Elbow/Flange options are not working even if those options are already enabled in Std Pref for re-loading same or creating new dgn for a workset |
931103 | Weld cell is not correct for branch connected to Header through Tap point |
931747 | Consistent KoQ in ProcessPhysical schema |
933887 | Incorrect placement of Note, when placed on slope/inclination of pipe. |
OpenPlant Isometrics Manager - Update 11 - 10.11.00.175
171793 | OPIM output not correct when connecting bypass line with an angle. |
178850 | In Managed Workspace OPIM Not picking Font from PW directory instead of that,Font is read from Local directory |
180007 | Dummy Leg Support diameter text incorrectly shown in BOM |
202391 | Part of Menu (Tooltip) stays on screen from previous interface as left over. |
205210 | Isometricis not Generated in OPIM when we use Russian Character(Cyrillic characters - Администратор Полюс) in Window User Name. |
280355 | Dimension angle text too big compared to dimension text |
381594 | Placing olet on 45 degree elbow throw an error. |
515891 | “Bentley DGN Preview Handler” not installing while installing OP products |
518682 | Outdated Report Definition qualifiers must be removed from Reports.def |
524334 | Iso Generation workflow through Autopipe app has broken |
600962 | Green status of generated iso is not maintained in OPIM shell for imodel created for AutoPlant-OpenPlant converted data |
631360 | Need to revisit strategy to display Plantsight imodel name along with AP models as different tabs |
701921 | OPIM should read the ProjectWise compiled configuration file shall be read including the cfg files created by the ProjectWise Control Blocks |
734378 | Scale Weld symbol via Override.txt not working |
743966 | Extracting isometric of idgn file from OPIM tool doesn’t show referenced Pipeline continuation. |
767219 | OPIM CE not Reading the Last Path & also not able to Control via any Configuration Variable as in v8i. |
778925 | Isometric doesn't Show the Information of Rotation for Olet & TEE. |
791927 | OPIM out session doesn't read workspaces root. |
851635 | Tag data and Tools menu options are not working |
