| Product(s): | AP_OPIM CONNECT Edition |
| Version(s): | 10.00.XX.XX |
| Environment: | Windows 10 (64 bit) |
| Area: | Settings\Attributes |
| Subarea: | |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
Output generated by OpenPlant Isometrics Manager shows the uneven distance from the component and dimension witness line. Normally Uneven distance is observed when components have different end conditions.
For ex: C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\Isometrics\styles\IFC\config
DimLift_FL = 10
DimLift_IF = 10
DimLift_BW = 10
DimLift_FT = 10
DimLift_SW = 10
DimLift_FW = 10
Review the End Condition and then add the missing End Conditions.
communities.bentley.com/.../autoplant---openplant-isometrics-manager-connect-edition
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
