| Product(s): | OpenPlant Products |
| Version(s): | 10.07.00.32 Update 7 & above |
| Environment: | Windows 10 (64 bit) |
| Area: | Installation |
| Subarea: | deployment Image |
| Original Author: | Swapnil Joshi, Bentley Product Advantage Group |
This process involves creating a deployment image of the application. It downloads all the components and prerequisites necessary for installing the application so that it can be installed online.
Deployment images are required when the administrators want users to use the consistent versions of applications. In this wiki article we shall create a deployment image of OpenPlant PID CONNECT Edition application.
communities.bentley.com/.../installation---autoplant-modeler-connect-edition
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
