Define local synchronization
This page is under construction.
  1. Start iTwin Synchronizer.
  2. Select the desired iTwin from the iTwin Name drop-down at the top of the dialog.
  3. Select the New button. The New synchronization page opens.
  4. Specify a name for the synchronization.
  5. Select an iModel to which the synchronization will be mapped.
  6. Browse to the location containing files to be synchronized. You can select multiple folders in a directory.
  7. Add files to the Synchronization from the selected directory using the Add button.   The list of files selected is displayed under Files section.
  8. Select a file that defines the Geographic Coordinate System using the corresponding radio button.   You can remove a file using the Unmap icon.
  9. Click Next. iTwin Synchronizer will check for required connectors and enable them.
  10. Click Save to save the new synchronization. The newly created Synchronization is listed along with information about the iModel and the files associated with it.
A new Synchronization is created and will be added to the list of synchronizations (if any are created already) in the iTwin. You can now synchronize changes to it, edit it to make any changes or delete it using the Synchronize, Edit and Delete buttons respectively, on the right.
