You can delete a connection by using the Delete action.
NOTE: You need to have View/Read/Write/Manage iModelHub permission defined in Role Based Access Control.
Delete a connection and associated changes
At the moment, you can make these edits to an iModel when deleting a connection:
Files from deleted connections can be synchronized with other connections.
