File is Protected
Error message: "File is Protected"
Issue:
- Synchronization was not able to open the file for processing and failed.
Cause:
- Please check that you have permission to both open and export the file. Fix any identified issue.
- Restart the synchronization.
- Contact Bentley support if this still fails for the same reason.
