Datasource Authentication Type Is Not Supported
Error message: "Datasource Authentication Type Is Not Supported"
Issue:
- Synchronization was not able to authenticate the connection owner and failed.
Cause:
- The synchronization owner authentication method to ProjectWse is not supported by the Synchronization service. Synchronization service supports only Bentley IMS authentication.
- Contact your ProjectWise Administrator to change the ProjectWise user authentication method to Bentley IMS and associate a Windows account with a Bentey IMS Account.
- Find out more how to enable IMS authentication IMS authentication in ProjectWise Administrator
