Geodetic coordinate system not supported
Error message: "Geodetic coordinate system not supported"
Issue:
- File which has a Geodetic coordinate system can not be selected (i.e. using degree units)
Cause:
- When creating a connection to a non-geo-located iModel, you can select a geo-located input file. It will set the iModel geographical coordinate system. If no file is selected, the first geo-located input file encountered will be used to set the iModel geographical coordinate system. Important to note that the other subsequent files added to the connection can be in meters or degrees.
- Define the coordinate system units to meters in the source file, that you want to set a geographic location and restart the synchronization.
- If the synchronization was canceled restart the synchronization.
