Please refer to the following table for the latest build version and build notes.
Date | Version |
Notes |
5/5/2025 | 1.1.647 |
Security fixes. Product uses all public iTwin Platform APIs. Enabled new auth exchange methods. |
6/9/2024 | 1.1.546 |
Security fixes. Special handling for Open Building Designer and Pro Structures. |
9/28/2023 | 1.1.469 |
iTwin Synchronizer product icon was updated. Includes user interface updates and new format for displaying synchronization reports |
8/30/2023 | 1.1.456 |
This version now supports assets in addition to already supported projects. The app header shows the option to choose an asset or a project. Includes internal fixes and security updates. |
7/12/2023 | 1.1.442 |
Internal fixes and updates. Users iTwins are directly listed, adding itwins to favorites is no longer needed. Fix for consent dialog workflow. The iModel connectors for both AVEVA Diagrams and AVEVA PID are no longer supported. If you have any questions please contact support. Note: New changes introduced, on installation of this new version users needs to sign-out and sign-in once to start viewing his iTwins list . |
6/20/2023 | 1.1.435 |
This version contains security patches and internal bug fixes. Supports FBX interchange file format. iTwin Synchronizer is now also available to download from Bentley's Software Downloads https://softwaredownloads.bentley.com/en/ProductDetails/2921 |
3/15/2023 |
1.1.407 |
This version contains internal fixes. |
2/1/2023 |
1.1.394 |
This version contains bug fixes and security patches. |
12/1/2022 | 1.1.374 |
This version contains additional authentication requirement. It will require user consent before starting the synchronization or un-map process. Supports displaying projects marked as favorites at the top of the projects list for a user. Internal fixes. |
9/22/2022 | 1.1.353 |
Resolved Connector download issue introduced by Antivirus, Reduced size of installer, Internal fixes |
7/26/2022 | 1.1.331 |
Windows 11 Support, Internal Fixes |
6/7/2022 | 1.1.321 |
Unmap Feature, ConceptStation Connector Support, WorkSpace Picker for OBD and ProStructures, Internal Fixes |
3/31/2022 | 1.1.301 |
Badgers Updates, Integration test, Delta Package, Internal Fixes |
2/11/2022 | 1.1.283 |
Internal Fixes |
1/31/2022 | 1.1.279 |
Badgers Report, Electron Forge Migration, iModelJS package Updates |
11/19/2021 | 1.1.258 |
Internal Fixes |
11/8/2021 | 1.1.256 |
Installer is Digitally Signed, Internal Fixes |
10/30/2021 | 1.1.254 |
Internal Fixes |
10/22/2021 | 1.1.251 |
Internal Fixes |
10/5/2021 | 1.1.244 |
UI Migration, Internal Fixes |
9/20/2021 | 1.1.239 |
Internal Fixes |
9/16/2021 | 1.1.237 |
Added Digital Signature to Exe, App Insights, Internal Fixes |
8/27/2021 | 1.1.229 |
Internal Fixes |
8/13/2021 | 1.1.225 |
Internal Fixes |
8/9/2021 | 1.1.224 |
Internal Fixes |
8/3/2021 | 1.1.222 |
Internal Fixes |
7/1/2021 | 1.1.212 |
UI changes for Projects having no connection, Internal Fixes, Added iModeljs Logging |
6/17/2021 | 1.1.208 |
Internal Fixes |
6/7/2021 | 1.1.205 |
Connector Background update and Inline Progress, Internal Fixes |
6/2/2021 | 1.1.204 |
Internal Fixes |
5/25/2021 | 1.1.201 |
Internal Fixes |
5/17/2021 | 1.1.198 |
Connectors Delta updates, Internal Fixes |
4/2/2021 | 1.1.178 |
Internal Fixes |
3/25/2021 | 1.1.174 |
Internal Fixes |
3/12/2021 | 1.1.168 |
Internal Fixes |
2/26/2021 | 1.1.161 |
Internal Fixes |
2/19/2021 | 1.1.159 |
Connector list is in separate menu "iModel Connectors", Added options for stale file processing, Internal Fixes for performance improvement |
2/1/2021 | 1.1.150 |
Version Number Fix in About Section, Internal Performance Fix. |
1/18/2021 | 1.1.141 |
iModel Connector and About Section Split, Tooltip changes and Internal Fixes |
12/18/2020 | 1.1.129 |
Addressed file search path limitations for iTwin Design Review Sessions |
12/10/2020 | 1.1.124 |
Internal Fixes |
12/4/2020 | 1.1.121 |
Fixes for Stale File Processing and Some internal Fixes |
11/12/2020 | 1.1.112 |
Internal Fixes |
10/29/2020 | 1.1.101 |
Internal Fixes for listing Bridge Issues at the end of Successful job run |
10/27/2020 | 1.1.99 |
Added support for "ESRI file geodatabase" directory mapping. |
10/15/2020 | 1.1.93 |
Internal Fixes for File Search Path patch fixes |
10/1/2020 | 1.1.88 |
Internal Fixes |
9/24/2020 | 1.1.82 |
Internal Fixes includes PowerPlatform support for ITDR sessions. |
9/3/2020 | 1.1.75 |
Internal Fixes |
8/24/2020 | 1.1.72 |
Support for locationzation for locales with '-' in their name (e.g 'zh-cn)' Support for using input files on mapped network drives Caching of remote bridge metadata for faster queries |
8/20/2020 | 1.1.69 | Internal Fixes |
8/11/2020 | 1.1.65 | Internal Fixes for processing i.dgn files |
8/6/2020 | 1.1.62 | Internal Fixes |
7/16/2020 | 1.1.50 | Refreshed UI components for easier identification. Improved messaging for when iModel Bridges need to be Enable for synchronization. internal fixes. |
7/9/2020 | 1.1.48 | Internal fixes |
6/25/2020 | 1.1.37 | Improved messaging if reference files are detected outside of the search path. Internal fixes. |
6/18/2020 | 1.1.30 | Internal fixes |
6/15/2020 | 1.1.22 | Support for the Open Buildings Designer iModel Bridge |
6/8/2020 | 1.1.16 | Internal fixes |
5/21/2020 | 1.0.146 |
Support for PlantSight SPPID iModel Bridge Support for Geo iModel Bridge Resolves an issue with Updating multiple iModel Bridges at the the same time Supports non-English Named View names |
5/14/2020 | 1.0.140 |
Improved messaging in the event there is an error when processing a Synchronization |
5/4/2020 | 1.0.126 |
View Incoming changes to the iModel since the last time you had synchronized your local file(s). This can be viewed by the expanded section called "Previous Changes" on the "Synchronize your Changes" page. This build resolves an issue where non-ASCII Characters would prevent an iModel Bridges to be run, if those characters were present in the user name. |
4/16/2020 | 1.0.106 |
Internal Fixes |
4/3/2020 | 1.0.92 |
The About dialog now displays information regarding which iModel Bridges are enabled Resolved an issue with popup dialog size during synchronization preventing viewing of issues Resolved issue where the iModel Bridge would be listed multiple times in the list of enabled iModel Bridges Resolved an issue where creating a new Synchronization prevented the MicroStation iModel Bridge from continuing to process without an restart to the iTwin Synchronizer |
