Data Access
Here you will find an explanation and best practices for solving Data Access-related synchronization errors.
Category: Data Access (DiskIO)
Data access errors are common in IT and data management. These issues can arise due to various reasons, including hardware failures, software errors, network problems, misconfiguration, authorization errors, Data Storage, and Disk Space issues.
Table of Contents
File not found
Error: Dwg_0203
 Error message: "File [...FilePath\FileName.dwg] was not found"
Issue:
Missing data in iModel.
Cause:
It typically indicates that the system or program couldn't locate the specified file at the specified path. This error can occur for various reasons and in different contexts. Here are some common scenarios where you might encounter a "FileNotFound" error.
Raster
Error: Dwg_0162
 Error message: "Cannot create raster attachment [failed copying file <File_Name>]."
Issue:
Cause:
Error: Dwg_0163
 Error message: "Failed downloading a raster file from URL or could not find its cached local path!"
Issue:
Cause:
Coming soon
Coming soon
