Synchronization category
Here you will find an explanation and best practices for solving synchronization-related errors.
Category: Synchronization
Synchronization errors refer to problems related to processing issues and inconsistencies.
Table of Contents
Config
Warning: Dgn_0060
 Warning message: "File <FileName> contains data from OpenBuildings Designer. Please unmap this connection and use the connector for OpenBuildings Designer for data fidelity."
Issue:
Cause:
Undefined
Warning: Civil_0002
 Info message: "Please review the best practices for creating a Civil iModel for information about how to address some of the issues"
Issue:
Coming soon.
Cause:
Coming soon
Coming soon
Element
Warning: C3d_0022
 Warning message: "Unable to get the Civil Domain base alignment for corridor [element name]"
Issue:
Coming soon.
Cause:
Coming soon
Coming soon
