| Product(s): | OpenPlant PID |
| Version(s): | CONNECT Edition 10.11.00.213 Update 11 |
| Environment: | Windows 10 (64 bit) |
| Area: | What's New |
| Subarea: | - |
| Original Author: | Bentley Product Advantage Group |
The following items summarize the new features and enhancements in the OpenPlant PID CONNECT Edition Update 11 release.
Feature |
Description |
Virtual Instruments and Tag Replication | Virtual Instruments When designing a PID there are situations in which you want to account for additional instruments in a bill of materials that you don't have room to show in the PID diagram itself. In such cases, you now have the ability to define virtual instruments that are associated with an existing instrument shown in the PID without having to place these instruments in the PID itself. Syncing the drawing will sync the tags of these virtual instruments to PlantSight so that they can be reported on. Tag Replication |
New Inline Class for Filters / Strainers New Water / Wastewater Components |
When placing In Drawing Reports you can now configure those reports to transpose the rows and columns to create horizontally oriented reports like this: The setting is found here: |
| The following enhancements were made to instrument loops: • Instruments you add to an existing loop will now automatically adopt the loop number so that the tags are consistently indicating that the instruments belong to that loop. • When selecting a Device Type Code for an instrument you can now select "FC Flow Control" as an option from the pick list. |
Enhanced Piping Tools |
Change pipe run to a new pipeline Change Pipe Run's Pipeline Place Pipe Run Flow Arrows Link pipelines between drawings without page connectors New Display Toggle in Tag Browser dialog |
Enhanced Drafting and Tagging Workflows |
Right Click > Edit Components Right Click Context Menu now displays P&ID icons Nozzle Annotation Page Connectors Renamed "Drawing" Tool to "Document Settings" |
Simplified Project Reuse Workflows |
Reusing Existing Documents
As part of this workflow you may also be presented with the PlantSight Project Storage Discrepancy dialog if the associated PlantSight Project differs from the one stored with the document. We simplified and clarified the options in this dialog as shown here: You can choose between the current WorkSet's configuration, continue to use the configuration stored with the document or work in offline mode disconnected from PlantSight. New Documents Inherit Plant Breakdown Structure from PlantSight Ability to update/restore deleted annotation |
PlantSight Integration and Synchronization Enhancements |
The following enhancements were made to the way OpenPlant PID integrates with and synchronizes data with PlantSight: • New Keyins allow you to create pre-configured ribbon buttons which set the synchronization direction between OpenPlant PID and PlantSight as shown here: |
Some features delivered with this edition of OpenPlant PID are specifically identified as "Technology Preview" features.
Technology Preview features are:
However, these features are provided to you as a courtesy and the primary goal is for the feature to gain wider exposure with the goal of full support in the future.
You may find these features useful in a non-production environment. You are welcome to provide feedback and functionality suggestions for a Technology Preview feature before it becomes fully supported. Bentley Systems intends to fully support Technology Preview features in a future release, at which time the features will no longer be identified as Technology Preview features.
OpenPlant PID CONNECT Edition Update 11 Help
