Generate Isometrics with Three Elbows Connected Consecutively in OpenPlant Isometrics Manager-CE
Product(s):OpenPlant Isometrics Manager CONNECT Edition
Version(s):10.XX.XX.XXX
Environment:Windows 10 (64 bit)
Area:Settings\Attributes
Subarea:
Original Author:Evander Cabalagan, Bentley Global Technical Support
There are some instances when generated isometrics of elbows connected consecutively will form a triangular shape which results graphically wrong. To generate this correctly, kindly follow the steps below.
1. Launch OpenPlant Modeler and open the piping model.
2. Apply a value in any of the properties in the elbow. For example, use Paint Code. Put a value of 1 for the first and second elbow.
3. For the third elbow, leave it blank.
4. Open overrides.txt and apply the given values below.
RULE: Three Elbows
INCLUDE = PAINT_CODE = 1
Scale = 2
5. Generate isometrics to verify results.
communities.bentley.com/.../autoplant---openplant-isometrics-manager-connect-edition
Still a Problem?
Comments or Corrections?
