| Applies To | OpenPlant CONNECT Edition | ||
| Product(s): | OpenPlant Modeler | ||
| Version(s): | CONNECT EDITION (10.11.xx) | ||
| Environment: | Windows 8.1/10 (64 bit) | ||
| Area: | Pipe | ||
| Subarea: | |||
| Original Author: | Joseph Gelacio, Bentley Product Advantage Group |
Define configuration variable OPM_PREFER_MEGALUG =1 to enable MegaLug joints.
The Series 2100 MEGAFLANGE Restrained Flange Adapter is a field-adaptable wedge style restrained flanging system. It has a restraint ring and a gasket ring which gives you the maximum amount of flexibility during and after installation.
A typical MEGAFLANGE Adapter is drawn in OpenPlant Modeler according to the following mapping of the properties in the Catalog\Spec mdb file.
To place Mega lug flange using auto-fitting , follow these steps:
