| Version(s): | CONNECT Edition (10.11.00.260) |
| Environment: | Windows 10 (64 bit) & Above |
| Area: | OpenPlant Modeler |
| Subarea: | Nozzle Equipment |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
In OpenPlant Modeler, nozzle manager shows few defined properties to nozzle manager dialog. Below wiki article explains procedure to add a new or existing property into nozzle manager dialog.
