| Product(s): | OpenPlant PID |
| Version(s): |
CONNECT Edition 10.11.++
| Environment: | Windows 10/11 (64-bit) |
| Area: | Cells |
| Subarea: | Graphics |
| Original Author: | Nikitesh Kawana, Bentley Global Technical Support |
If user wishes to add Label/ text or add graphics to existing cell component, this Wiki will help to accomplish that. In this case we will do make changes in Valve
- Start OpenPlant PID CE
- Open .dgn file with concerned Workspace and Workset
- Place a Ball Valve
- Open Key In Browser, and type ‘’ pid component dump’’
- Open Valve.cel file located at
C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\WorkSpaces\Workspace\WorkSets\Workset\Standards\OpenPlant\PID\cell
- Go to model and open Hvalve_BALL_Open
- Add Required Text/Graphics to cell
- Do save cell and save settings
- Go to Workfile dgn and run Key In Browser with command ‘’ pid component redraw cells’’, graphics of cell will be changed
communities.bentley.com/.../how-to-add-the-reattach-instrument-bubble-and-annotation-option-in-the-openplant-pid
