| Key: | |
| CS – Client Server Article | FAQ – Frequently Asked Questions |
| TB – Technical Bulletin | TN – TechNote |
| VID – SELECTsupport Video |
Bentley Plant projects created with the Project Administrator (PA) application may be configured to use Bentley ProjectWise as the data repository and also to manage user authentication. There are a number of significant advantages to using ProjectWise as your project environment. Some of these are briefly described below:
Bentley Connector for eWarehouse: through an association with ESSI llc, Bentley Systems has developed an application to link Bentley Plant application component and document data stored in Bentley ProjectWise to their associated enterprise level data that is stored in ESSI's eWarehouse project database. Contact your Bentley Sales Representative for more information.
Bentley's Technical Support Group welcomes any and all comments you have on this Wiki entry, as long as they are posted in the "Comments" area below. THANK YOU!
