AutoPLANT Modeler CONNECT Edition
Work remotely or connected with the market’s most productive and easy-to-use 3D plant design and modeling software
The applications included in AutoPLANT Modeler CONNECT Edition suite are AutoCAD-based tools used for designing, managing and operating industrial plant facilities of all sizes or complexities. These products integrate with Bentley ProjectWise application to provide seamless integration between the engineering teams, document management and related business systems.
Common Tools for Bentley AutoPLANT CONNECT Edition English
It includes common tools for AutoPLANT products which are Bentley Project Administrator, Bentley Configuration Editor, Bentley Vision, Bentley Document Manager, Bentley Data Manager, Bentley Datasheets, Bentley Project Packager and Bentley Split Merge. For additional information on release notes and system requirements see the readme Document.
Modules included in this install set are:
  • Bentley® AutoPLANT Piping – Spec-driven 3D design of piping with advanced routing and editing features. Drawing production includes orthographics (plans, elevations and sections) using paperspace viewports and exporting 3D model data to produce finished isometric drawings. In addition to an extensive catalog of piping components this application can also place 3D pipe supports, instruments, conduit, cable tray and HVAC components. Please refer to the AutoPLANT Help for more information.
  • Bentley® AutoPLANT Equipment – Fast layout and design of intelligent equipment vessels and nozzles. Full pipe connectivity, extensive equipment library and easily designed custom assemblies.
  • Bentley® AutoPLANT Raceways – Fully-featured 3D electrical layout and design application including conduit and cable tray specifications. Note: This application is a subset of the component modules available to the Piping application.
  • Bentley® AutoPLANT Isometrics – Object-based drawing tools used to create isometric drawings without a 3D model using the same piping specs as the full 3D piping application.
Dependencies are:
ProjectWise Design Integration CONNECT Edition - Client Setups (English)
OpenPlant Isometrics Manager CONNECT Edition x64 (SES) Update 4 (English
CONNECT Licensing:
 This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
Available on Select:-
AutoPLANT Modeler V8i
External Links
Check Videos  Content - LEARN Server
Comments or Corrections?
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
