Key: | |
CS – Client Server Article | FAQ – Frequently Asked Questions |
TB – Technical Bulletin | TN – TechNote |
VID – SELECTsupport Video |
The Import/Export feature supports output to a piping component format (PCF) for input to Alias Limited’s ISOGEN software for the automatic generation of ISOGEN isometrics. Drawing Flattener produces flat, two-dimensional drawings including elevations, plans and sections from the 3D model. Suitable for fast edits on construction drawings.
Bentley's Product Advantage Group welcomes any and all comments you have on this Wiki entry, as long as they are posted in the "Comments" area below. THANK YOU!
