| Product(s): | OpenPlant Isometric Manager |
| Version(s): | CONNECT Edition (10.11.0.175) |
| Environment: | Windows 10 (64 bit) & Above |
| Area: | Settings / Attributes |
| Subarea: | Annotation / SPOOLID |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
To label the Spool ID in OpenPlant Isometrics Manager, through OpenPlant. Various syntax can be achieved using the attributes of OpenPlant Isometrics Manager and with 'User Labels' option through Isometrics configuration dialog box.
Requirement was to achieve the Spool ID label with syntax like LINENUMBER-NUMBER/LETTER of a spool. Matching attributes can be used to customize the 'Pipe Spool Labels' option present under 'User Labels' node in Isometrics configuration dialog. Below are the recommended way to achieve it.
User can customize the Line number labeling under ‘User Labels’ option present in Isometrics configuration dialog box. Currently under ‘Pipe Spool Labels’ it has been defined as $(SPOOLID).
