| Product(s): | OpenPlant Isometrics Manager CONNECT Edition | ||
| Version(s): | 10.XX.XX.XXX | ||
| Environment: | Windows 10 (64-bit) | ||
| Area: | Settings/Attributes | ||
| Subarea: | - | ||
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
OpenPlant Isometrics Manager users have a requirement in showing Shop, Field, and other weld information in Weld Report. Those details must be assigned in the model and will be visible in the seed file/template. This wiki article is applicable for OpenPlant Modeler and AutoPLANT Modeler.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
