| Product(s): | OpenBuildings Generative Components | ||
| Environment: | N\A |
I would like to select a set of Points in a Point series with various methods.
A set of Points in a Point series can be selected using either of the below mentioned methods. The same process can also be applicable for other items such as Arcs, Lines, etc.
