| Product(s): | OpenBuildings Generative Components | ||
How to create a Parabolic Curve using OpenBuildings Generative Components?
GenerativeComponents is an associative and parametric modeling system used by architects and engineers to automate design processes and accelerate design iterations. Please go through the following video tutorial that shows the way to create a parabolic curve using the same.
