| Product(s): | OpenBuildings Generative Components | ||
| Area: | Tutorial |
I am unable to see concrete sections in the cross-section dialog in the structural node. How to get the sections over there?
Please have a look at the attached video which will demonstrate how we can create an mdb file from an xml file. Which can be read by the Structural member node.
