| Product(s): | OpenBuildings Generative Components | ||
| Environment: | N\A |
We want to integrate OpenBuildings Generative Components with ProjectWise.
Firstly, we need to go to ProjectWise Administrator and create a new application.
Now scroll down and search for Generative Components W/ OpenBuilding Designer. Right click on the same and select Properties and do the necessary changes as shown in the below image.
Now we need to go to ProjectWise Explorer and locate the desired file, right click on it and then go to properties and from the application drop-down select the previously created application
After doing all the previous steps, right click on DGN, which you want to open in OBD-GC session, and Select 'Open With' option, Browse the application called OpenBuildings Designer with description as Generative Components Connect Edition. Click on Ok & that DGN file will open in Generative Components session.
